How to establish hierarchy between Epics and User stories
Khurshid Akbar August 23, 2011
Hi Folks, I need to link Epics to User Stories so that when all attached User Stories are completed the Epic is marked as finished.
Similarly User stories could have relationship/dependencies with other User stories, Parent & Child relationship; Predecessor & successor relationship. Is there something similar in Greenhopper/Jira
Khurshid Akbar October 7, 2011
In the Epic there is a field for entering the Epic/Theme enter the keyword that you want to describe the Epic with and then in the User Story there is place to select one of the Epic/Theme that you have defined
Dimitar Dimitrov
To use the the EPIC field as designed, you should use ussie ID and not just an arbitrary word as your comment seems to imply. This makes the epic screen of GreenHopper to show the EPIC as an ad-hoc aggregation of its comprising issues, summarizing time worked, time remaining, story points, etc.
In Green Hopper 6.2+ the Epics have been completely overhauled, so you'd better check the GH docs.
Igor Sereda [ALM Works]
April 3, 2012
Just in case this is still an open question, Structure Plugin does a good part of this job:
  1. "GreenHopper Synchronizer" creates and maintains hierarchical structure of Epics and Stories - it can update Epic/Theme field for you if you create new stories or move stories from one epic to another with drag and drop.
  2. "Status Rollup Synchronizer" looks out for sub-issues (Stories) that are resolved and makes parent issue (Epic) resolved automatically. There's a lot of configuration flexibility involved due to customizable workflows.
Hope this helps.
Igor
Disclosure: I work for the company behind Structure plugin.
Deleted user November 18, 2012
It appears that the latest version of Greenhopper (6.0+) uses a different field and field-type for linking epics to issues on Rapid Boards. It appears that the Structure Greenhopper Synchronizer does not support this new format. Do you plan to support this soon?
November 18, 2012
I believe the new Epics were introduced in GreenHopper 6.0.6 as a labs feature but perhaps will soon be mainstream. Structure's synchronizer does not yet support it, true. We plan to take a close look and see what we can do.
It might turn out that Structure won't be able to integrate with the new epics without corresponding API in GreenHopper. I've posted this feature request for GreenHopper team - https://jira.atlassian.com/browse/GHS-6542 - you can vote it up! Here's the feature request for this in our JIRA: https://jira.almworks.com/browse/HJ-1028 - feel free to vote/watch/comment.
Igor
March 18, 2013
for the record, Structure 2.1 works with the new Epics, introduced in GreenHopper 6.1
Dimitar Dimitrov
Currently JIRA does not provide such a functionality - Epics are just labels and usage convention that is somewhat automated by GreenHopper.
You can link issues and visualize the graph using the Link Hierarchy plugin. There is no functionality to have JIRA automatically resolve an issue when it's linked siblings are resolved (it doesn't seem very useful in the common case either).
Kinto Soft
December 6, 2012
The Links Hierachy Structure plug-in (internally) transforms Greenhopper Epic labels into issue links, so you can view those parent/child relationships on a hierchical tree structure.
Pablo
Learn more
