We have a couple of multi select custom fields with a bunch of different options. As of right now it gets cut off. Is there any way to expand the multi select so that we can see the full text?
Does this cover what you are looking for? :)
Hi
I'm using the javascript in the description but the spacing on the multi select is still the same cutting off the text inside
Is there another option that we can use?
