How to extract the Assignee from Jira using a script
CostaM April 7, 2022
Hi is there anyone that can assist in helping correct the code on this script to enable me to extract the actual assignee name, when using the below, it returns some kind of key rather than the actual name:
select concat (p.pkey, '-', j.issuenum) AS IssueKey,
j.summary,
t.pname as issuetype,
s.pname as status,
u.lower_user_name as assignee,
concat(u.first_name,' ',u.last_name) as "assignee full_name"
from jiraissue j
left join project p on j.project = p.id
left join issuestatus s on s.id = j.issuestatus
left join issuetype t on j.issuetype = t.id
left join app_user a ON j.assignee=a.user_key
left join cwd_user u on u.id=a.id;
thank you
Antoine Berry
Hi @CostaM ,
Your query should properly display the assignee full name.
You could also try
u.display_name
if you want the name as it is actually displayed in Jira.
CostaM April 11, 2022
Thank you Antoine.
