How to fetch all the issues comes under a single project by projectID?
sirsendu_gope June 17, 2020
I am trying to fetch all the issues comes under a specific project by projectId. I search a lot but couldn't get any proper answer or what I got, that is not working.
I am hitting this api,
"/rest/api/2/search?jql=project={projectId}&maxResults=1000"
and I am getting this error,
["Error in the JQL Query: Expecting operator before the end of the query. The valid operators are '=', '!=', '<', '>', '<=', '>=', '~', '!~', 'IN', 'NOT IN', 'IS' and 'IS NOT'."]
Do anybody know the answer. That would be so helpful.
Though the above link is working from browser but it was not working while try to hit it from Java side with this command
HttpResponse response = getResponseFromUrl(parameters, new GenericUrl(url));
where parameters are the oauth parameters
and Url is the Jira URl.
To get the proper response, need to pass the url like this way,
https://example-dev1.atlassian.net/rest/api/2/search?jql=project+in+(10002)&maxResults=1000
Muhammad Ramzan_Atlassian Certified Master_
June 17, 2020
Your query is right, but plz make sure what you are doing here {projectId} , if its paramaterized then make sure you passing the right project id value
This is the full URL
https://example-dev1.atlassian.net/rest/api/2/search?jql=project=10002&maxResults=1000
which I am calling.
I am getting result for
/rest/api/3/project/search?jql=&maxResults=200
this query but not for the above one. I am getting error for the above one.
The project id is good. I can fetch that particular project by that id.
Frederik De Roover
June 17, 2020
That should work.
ex:  https://jira.app.*.com/rest/api/2/search?jql=project=ID&maxResults=1000.
Perhaps you don't have the necessary rights to make the call?
I am getting response for other URL like,
but not for this,
Register Now
