Sign up Log in
How to filter EPICs of one Initiative in timeline view?
João Bento
January 10, 2017
Use case: I would like to understand what are the EPICs of a specific Initiative when I'm calculating the timeline, so that I can adjust some priorities. This is also valid between stories and EPICs.
Aaron Steinmetz
I don't know how to do it properly, seems like a reasonable feature to expect though. You might be able to assign a Label to each Initiative, which should in turn label each epic and story with the same label. Then you can set the display to Group by Label.
You could do the same thing with Components. It's not ideal, but i think it is a feasible workaround.
Register Now
Upcoming Jira Events
