How to filter all tickets, regardless of project, that has a parent in a specific project
jorge_negrete
October 19, 2025
Hi All!
I'm trying to create a plan that includes Epics in a specific project (E.g. Project 'ABC'), which may have tasks/stories that belong to other projects without having to set up a filter that relies on adding a label to each ticket that sits outside the project where the Epic is from.
Is there a way to create a filter that automatically filters in ALL tickets with a "Parent" that sits in Project 'ABC'?
Jorge
6 votes
Christos Markoulatos
Hey @jorge_negrete 👋 welcome to the community!
Native JQL can’t do this automatically. You can only query one parent at a time like:
parent = ABC-123
To pull all children of Epics in Project ABC, here are your options as far as I know:
Advanced Roadmaps (works even if issues aren’t in a plan)
issue in portfolioChildIssuesOf("project = ABC")
ScriptRunner
issueFunction in childrenOfIssuesInQueryRecursive("project = ABC")
3rd-party apps
  • Advanced JQL Functions (Cloud)
  • Enhanced Search (Adaptavist) (Cloud)
  • More Extension for JQL (Cloud & DC)
  • JQL Booster Pack (DC only)
  • Links Hierarchy (Cloud & DC)
Hope this helps!
jorge_negrete
October 23, 2025
Hi Christos,
Thanks for your reply! I'll play around with the options above. Just for clarity, my understanding is that "Advanced Roadmaps" and "Plans" are the same thing aren't they? "Plans" is just the new name for them... just like "Projects" will soon be renamed "Spaces"? Did you mean to say "Project" in the first option you mentioned instead of "Plan"?
ENTERPRISE
