I want to filter the issues according to their security levels but there is no "security level" criteria.
I follow "Issues and filters" menu,
then I click "Advanced search",
then click +More,
But there is no "security level" criteria. Is it possible to add it manually? Or there is no way to do that?
Thank you,
Please follow below link for filtering issues according to security level.
https://confluence.atlassian.com/jirakb/how-to-filter-issues-based-on-security-level-785325857.html
Thank you! Couldn't find it in search for some reason until now.
Does it mean that you have turned up with zero results after search ?
In that case, please check if your account has been provided with appropriate permissions, in order the view the issues of that particular security level.
No, sorry for misunderstanding. Your answer works for me, thank you. :)
