Suppose I have 1000 projects in my jira instance. How can I find the list of all projects that are not active (any updation) from last one year?
Please suggest solution if we can use REST API for this?
Thanks in advance!
You can run below SQL on your Jira database. It'll give you list of projects which are not updated after a specific date and time. You might have to tweak the date and time part in the 'where' clause. I ran it on PostgreSQL.
select
pname,pkey,created as project_createtd,updated as project_updatetd
from
project
where updated <= '2019-10-01T02:15:00.102738Z'
Hi @Narendra Kumar ,
Under Administration > Projects there's a column where you can see the last time an issue was updated in the project.
@Edwin Kyalangalilwa, is that an image from Cloud? Not sure it is and I do not have that field in my Projects page and I checked another instance as well w/o success. I wonder if this is Server specific?
You're right, i missed that this is a question related to cloud.
@Narendra Kumar Please disregard my above answer.
Hey, just to update this old thread with new information :-)
This is now available in CLOUD! See Screenshot from one of my cloud instances... Yup, you can now see "Last Issue Updated" and sort by that in the manner @edwin mentioned above!
@Russell Zera , is this standard or premium? I don't see in my standard instance (yet).
ohhhh nooooooo... Premium strikes again! sorry... I'm on Premium
