How to fire a custom event
Kathleen Jacobs
I'm following this walkthourgh: https://confluence.atlassian.com/display/AOD/Adding+a+Custom+Event
But when it gets to setting it in Post Function of a walkthourgh, I'm not seeing what i should choose.
I'm trying to set up a notification event that trigger when creating a ticket, only with a specific workflow.
Jobin Kuruvilla [Adaptavist]
February 18, 2013
You will have to edit the post function that fires the event. You can only throw one event at a transition. Default event is normally Generic Event.
Kathleen Jacobs
thanks! that worked
Rob Kachmar
April 26, 2021
Thank you very much! This is a critical detail that should have been explained in this "Add a custom event" article: https://support.atlassian.com/jira-cloud-administration/docs/add-a-custom-event/
Kathleen Jacobs
When i go to the workflow, go to post function, and click add, i'm not sure what to select.
I see my list of things i can do for a post function, but not sure what to select that will get me to fire an event
February 18, 2013
WHat exactly are you not seeing? You custom event in thr dropdown to fire events?
Register today
