×Hi @Dawid Adamczyk -- Welcome to the Atlassian Community!
Would you please clarify your question a bit, and perhaps consider posting images or more details of your multiple rules and how you expect them to interact? Thanks!
Are you noting that when using the send web request ACTION, it sends...and when using the incoming webhook TRIGGER, it does not detect it? Apologies if I am misunderstanding your question.
Hi @Bill Sheboy
Many thanks for your swift reply!
Yes, you understood my issue completely.
I have a rule called "Contract signed" (below), which starts on one board (HRB) when an issue is transitioned from "In Progress" to "Done".
This rule sends (Then: Send web request, POST) a web request to the address where another rule (Test, on board ITB) is listening for web requests. This one always works - in logs, there's always a success. I also validated it with Webhook.site. Works like wonder.
Here's the rule "Test" in another board, ITB, that listens for the incoming webhooks:
This one doesn't work at all - the only thing Audit log registers is Config Change. I tested it via external portal and sent a few POST requests. None of them worked. Logs show nothing. I copied the rule and also created a new one which is 1:1 the same. No results as well.
Dawid
