Hi all
I'd like to to automise the following process:
If I create an epic and set the value of a custom field [Generate CR] on a certain status [General], several [6] linked tasks should be generated.
Two of those six tasks should also contain several linked subtasks [not defined how many yet].
Now my automation works so far, that all tasks are generated and linked to the specific epic.
But I cannot make it work to get the substasks created and linked to the specific task.
How can I fix this automation?
I'd prefere to have it in one automation and not an additional one.
Below some screen shots:
Thanks a lot for your support.
Cheers
I have done something similar and they way it works for me is to select the field "Parent" on your Create Task step in the automation:
I then set the field like so:
Hi Phil
Thanks for your comment.
To clarify: the automation works for the tasks but not for the subtasks.
I've now added a branch and it was possible to generate the subtask automatically.
The only thing what not works is to link subtask to the task.
Cheers
ah, I understand.
If you want to name your subtasks differently for each task then give this a try:
else, you could create subtasks at the end of your automation using something like this:
