How to get accountId from username
Miraculous Ladybug March 31, 2023
When I have the username how can I get the accountId from the user? How can I find it via REST API? I dont have any other data except for the user name
Mikael Sandberg
You can use the Find users endpoint to do it, it takes either the display name or the email address to find the user. Get user endpoint used to take the username, but that has been deprecated because of GDPR, you can see the notice here.
Thanks, is there a way to get the display name or the mail address via the user name?
Mikael Sandberg
If you are on Data Center/Server then the Get user endpoint still takes the username, it is only on Cloud that it does not, and on Cloud your username is your email.
thank you, i didnt know that
Like • Mikael Sandberg likes this
Elena Dzhordzhilova April 13, 2023
About the Cloud, I would want to ask if it is possible to get the user’s email address via API, because the information which I get is for display_name, nickname and uuid. display_name and nickname are totally different from the username or email address. On other topics about it I see that it is private information, but shouldn’t be available for access via token or AppPassword? Is it possible to get such an information? Even with the specific uuid of the user with https://api.bitbucket.org/2.0/users/<uuid>  does not return anything specific as this.
Thank you in advance!
Best regards!
Mikael Sandberg
@Elena Dzhordzhilova This should be a separate question. Based on the documentation for Bitbucket you can only get the email address for the current user, there is no way of getting the email address for other users, at least not at the moment. For Jira and Confluence you can get the email by accessing the Get user endpoint.
