×I'm trying to pull out the accountId based on an email address using automation.
When i try to validate web request config with a project key, I see the payload with my custom field value:
"customfield_10094": "my_email@email.com",
But when I log {{webResponses.body.first.accountId}}, it turns up empty. What am I doing wrong?
I have the same API using this:
And finally I'm get the web response using this variable: {{webResponse.body.accountId}}
Seeing your details, maybe you just need to avoid to get first in your web request response.
Have you tried this?
I updated with Web request body: EMPTY and {{webResponse.body.accountId}}, but still getting an empty value.
Audit logs:
Action details:
USER CONDITION
The following issues passed:
<key>
SEND WEB REQUEST
Successfully published web request
LOG ACTION
Log
my_email@email.com (customfield_10094) and <EMPTY> {{webResponse.body.accountId}}
I've also tried {{webResponse.body.emailAddress}} and {{webResponse.body.accountType}} and it returns nothing.
When I do run <jira_url>/rest/api/3/user/search?query=my_email@email.com, I get a json response and can see accountId, emailAddress, accountType and lots of other data.
I have a suspicion that my headers are not correct, even though I get a 200 response. Can you give me an example of how it should be?
To Header I'm using my token converted to base64. Similar to this: Basic XXXXX.
You can conver get this base64 converted token in Postman headers if you're using Postman to test or you can generate a base64 token converted using some websites, like this one: https://base64.guru/converter
In the left side fill the box with the content: your-email:your_api-token. Click to encode to base64. Then copy the result and in your automation your header need to be like this:
Basic your-token-x64
Here a full print of my automation rule to test it.
URL: https://jira_site/rest/api/3/user/search?query={{issue.customfield_XXXX}}
Method: GET
Web Request Body: EMPTY
And ensure that you has checked the option: Delay execution of subsequent rule actions until we've received a response for this web request
And it works perfectly. Could you review your web request and response body to ensure that is similar as this one?
thank you Fernando, encoding in 64 your-email:your_api-token also solved the issue for me
