I have a jira projectKey,and I want to get all issueKeys by rest api.
Hi Ronaldo,
I'm going to quote an answer (with a bit of updates to direct at this question) from a previous answerer as that person has given a very good description and brief guide on how to use Jira's REST API:
- Get the total issues in a project with a basic and 'quick and light' query
URL: https://<server>/rest/api/2/search?jql=project=<YourProjectKey>
- This gives a result like -->
{ "startAt": 0,
"maxResults": 50,
"total": 24,
"issues": [...] }- Iterate over the total number of issues to fetch the desired details/fields of each issue.
- Note: Maximum allowable fetch seems to be 1000 issues at a time.
- We can also filter the fields that we are interested to fetch. Since you are only interested in key, we will filter fields shown to just key.
search on URL: "https://<server>/rest/api/2/search?jql=project=<YourProjectKey>&fields=key"
I highly suggest reading the previous answerer's post as it will give you more context and has some other useful tips to handle projects with > 1000 issues - sayeed1310's answer
