How to get all users in jira using rest api
sonika jain September 10, 2015
Hello Everyone !!
I want the list of all user in JIRA account (online) using rest api or want to search user based on email address.
I am trying to get this using below url but this is retuning empty  "[0]" values
https://testjira.atlassian.net/rest/api/2/user/search?username=sonika.jain@test.com
Please suggest
Krishna Prasad PS
October 11, 2017 edited
It is possible to get the list all users (may be with in the limit of maximum returnable results). We need to use the search API.
https://servername/rest/api/2/user/search?username=%
The wildcard character to be used for this purpose is "%".
Max Makhrov
or
https://servername/rest/api/2/user/assignable/multiProjectSearch?projectKeys=KEY1,KEY2,KEY3
Both requests give me active users only. How about all users?
Like • 3 people like this
Anuradha October 2, 2018
what if users are more than 1000 ?Is it working if startAt=1000 and maxResults=2000?
It's not working for me.
Paul Y December 3, 2018
Try ...username=.   (dot)
Stefan Schwaha
May 13, 2019
"_" stopped working for me with jira cloud. but a "+" instead did the trick
Like • 2 people like this
Kyle McCauley May 24, 2019 edited
"+" seems to stop at 100 results. Even using pagination with maxResults=100 and startAt=50 seems to have it stop at the same 100 users each time.
IE: rest/api/3/user/search?query=+&maxResults=100&startAt=0  puts me somewhere in the T's for my users. Then using rest/api/3/user/search?query=+&maxResults=100&startAt=100 produces a blank request. There are definitely users missing. I've tried increasing maxResults to 1000 with no luck.
Tommy_Gingras
May 30, 2019
We are having the same trouble :
https://url.atlassian.net/rest/api/3/user/search?startAt=0&maxResults=1000&username=+
Returns the 100 first entries
but
.atlassian.net/rest/api/3/user/search?startAt=100&maxResults=1000&username=+
returns nothing...
@Kyle McCauley did you find a workaround ?
Like • Andrew Goss likes this
Kyle McCauley May 31, 2019
@Tommy_Gingras
I have not at this point in time. I tried using some of the old "get all" queries by replacing the '+' with _@, . , and ? with no luck.
@Tommy_Gingras I did find a workaround. You can use the group/member search:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/#api-rest-api-3-group-member-get
You'll have to use pagination to iterate through as they only return 50 results, but I do see all of my users now. The Jira-Users is the default group which I believe every user should be a part of from my understanding.
https://yoururl/rest/api/3/group/member?groupname=jira-users&startAt=100
Tommy_Gingras
June 3, 2019
Thanks for your answer,
That route required to be admin, but unfortunately my profile isn't :(
"errorMessages": [
"You are not authorized to perform this action. Administrator privileges are required."
"errors": {}
Jaime S
September 10, 2015
Hi, Sonica.
About getting all the users, this should give you some information:
https://answers.atlassian.com/questions/140370
Jaime Kirch da Silveira
Atlassian Cloud Support
Taha Khanzada
September 10, 2015
Hi Sonika,
I am not sure if you can get all users from JIRA rest api, but surely you can search user by username, email id or text from below query
If you are running this directory in browser then make sure you are logged in to JIRA before running this.
You will get Empty value also if there is no user with that email id or name.
I have tested using CURL and running in browser both are working
curl -u testjira:testjira https://testjira.atlassian.net/rest/api/2/user/search?username=sonika.jain@test.com
Taha
