Hi all,
I want to get all boards from Jira and found method with python, but something get wrong. Who try this kind of method please help
from jira.client import JIRAfrom jira.client
import GreenHopperimport logging
import refrom .rest_client
import AtlassianRestAPI
options = {'server': 'http://localhost/'}
jira = JIRA(options, basic_auth=('username', 'password'))
gh = GreenHopper(options)
def get_agile_board_configuration(self, board_id)
url = 'rest/agile/1.0/board/{}/configuration'.format(str(board_id))
return self.get(url)
I get this error.
File "board.py", line 11
IndentationError: unexpected indent
Code I get from github
https://github.com/atlassian-api/atlassian-python-api/blob/master/atlassian/jira.py#L984
Thanks in advance,
regards,
Alik
Delete the first "space" character at the start at line 11 - before "def ".
And as I see from the copied script you should add 2 or 4 spaces at the start of next line (starting with "url = ") and the same spaces to the last line (starts with "return ")
