I have created an eazybi report for created and closed tickets with time dimension in row. For example, with having this report if the user wants to view created and closed tickets for a specific date and time in the same report how to create it
Hi @Thrisha ,
If you already have the Time dimension on report rows, you might add it to the page filter with a few clicks.
Expand the Time dimension box in report editing mode and click on [Pages] button.
That will add the Filter drop-down to the report screen and allow users to filter out desired dates.
Please read more about adding page filters here - https://docs.eazybi.com/eazybi/analyze-and-visualize/create-reports#Createreports-Pagedimensions
Oskars / eazyBI Support
Hi @Thrisha ,
I suggest writing to eazyBI support directly over e-mail and describing your total reporting requirements like what measures and over what period ou would like to report.
What categories (dimensions) are you planning to use to slice the data and what of that should be available for the user to adjust and what should be hard-coded.
Knowing all those details would allow suggesting you a reasonable solution.
Rebards,
Oskars / eazyBI Support / support@eazybi.com
Thank you for your help @Oskars Laganovskis!
@Thrisha Hello, I just wanted to share for you and other users that Atlassian Marketplace Apps typically have a direct link to their support within their Marketplace page as seen for eazyBI:
