How to get epic tasks in script filed
Katarzyna Kacperska April 16, 2024
I'm using Script Fields in Script Runner.
For an epic I want to display any information from its tasks.
To download these tasks I use the command:
def links = issueLinkManager.getOutwardLinks(issue.id)
but this returns me not only issues in epic but also other issues linked to it.
How to get only issues which are connected via thic Epic by epic link ?
April 16, 2024 edited
Hi @Katarzyna Kacperska
The approach you are trying alone will not work.
You need to perform other steps for the filtration to work correctly.
Below is a sample working code for your reference:-
def issueLinkManager = ComponentAccessor.issueLinkManager
if (issue.issueType.name == 'Epic') {
def listOfTasks = issueLinkManager.getOutwardLinks(issue.id).collect { issueLink ->
if (issueLink.destinationObject.issueType.name == 'Task') {
}.findAll {it != null}
listOfTasks
} else {
return
Please note that the sample working code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a screenshot of the Scripted Field configuration:-
Below is a test output:-
If you observe the screenshot below, as configured in the Scripted Field code, it will only display all Task issue types that belong to the epic.
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
Great to hear the solution worked for you. :-)
Please accept the answer provided.
Ram
Katarzyna Kacperska April 17, 2024
Hi Ram,
Thank you very much for your answer. I used this commands:
links.each { issueLink ->
        if (issueLink.issueLinkType.name == "Epic-Story Link") {
but the solution you provided is better.
Kate
SERVER
Register today
