how can I find the id of "original/generic" workflow scheme that I've been newly created? not the one that has been applied to any project. AFAIK, The only way to know the workflowscheme is to retrieve from this api which is the workflow id that has been applied to a project.
GET /rest/api/2/project/{projectKeyOrId}/workflowscheme
I tried to input the id to the POST create new project below in the "workflowSchemeId" :
POST /rest/api/2/project
but get this error,
Could not add project: 400
msg: {"errorMessages":["Can not construct instance of java.lang.Long from String value 'SCALAR(0x3b54c58)': not a valid Long value\n at [Source: org.apache.catalina.connector.CoyoteInputStream@61b8486f; line: 1, column: 99] (through reference chain: com.atlassian.jira.rest.v2.issue.project.ProjectInputBean[\"workflowSchemeId\"])"]}
Which Jira version do you have? This rest call is only available for Jira version 8.7.1.
Here exists: https://docs.atlassian.com/software/jira/docs/api/REST/8.7.1/
Here not: https://docs.atlassian.com/software/jira/docs/api/REST/7.6.1/
Edit:
I have tried on Jira verstion 8.5.1 and it does not work. This is why i am asking :)
well i tried now in Jira 8.8 and its working perfectly.
GET > http://localhost:8080/rest/api/2/project/10400/workflowscheme
Sorry for the late response!
I just made the test now. As you can see in the following images , yes i could succesfully create one :)
I still get this error,
Do you know why?
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
