How to get issue type type object?
arama mihai
April 20, 2021
I have the following piece of code:
def firstProjectKey = 'ABC'
def getFirstProject = projectManager.getProjectByCurrentKeyIgnoreCase(firstProjectKey)
def firstProjectIssueTypesList2 = itsm.getIssueTypesForProject(getFirstProject)
def issueTypeScreenSchemeManager = ComponentAccessor.getIssueTypeScreenSchemeManager()
for (issueType in firstProjectIssueTypesList2){
log.warn(issueType)
def fieldScreenScheme = issueTypeScreenSchemeFirstProject.getEffectiveFieldScreenScheme(issueType)
I run this in the console and i get:
groovy.lang.MissingMethodException: No signature of method: java.lang.String.getEffectiveFieldScreenScheme() is applicable for argument types: (com.atlassian.jira.issue.issuetype.IssueTypeImpl) values: [IssueConstantImpl[[GenericEntity:IssueType][sequence,null][name,Project][iconurl,/secure/viewavatar?size=xsmall&avatarId=12315&avatarType=issuetype][description,Issue Type for GLC][style,null][id,10403][avatar,12315]]]
at Script1787.run(Script1787.groovy:204)
What is the format that it wants? I saw in:  https://docs.atlassian.com/software/jira/docs/api/7.0.0/com/atlassian/jira/issue/issuetype/class-use/IssueType.html that it expects a "issue type type" .. but how does that look, where to get it from?
Thank you!
3 votes
Hi @arama mihai,
If you want to get the Issue Type using the ScriptRunner console, you could try something like this:-
def issueManager = ComponentAccessor.issueManager
def issue = issueManager.getIssueByCurrentKey("MOCK-44")
log.warn "====>>> ${issue.issueType.name}"
 Please note, this sample code is not 100% exact to your environment. Hence, you will need to make the required modifications.
Below is a print screen of the console for your reference:-
I hope this helps to solve your question :)
Thank you and Kind Regards,
Ram
arama mihai
April 20, 2021
Hi @Ram Kumar Aravindakshan _Adaptavist_ ,
Thank you very much for your reply! I am, however, trying to get the screen scheme out of a issue type screen scheme, and I am not using any issues. I used :
def issueTypeScreenSchemeFirstProject = issueTypeScreenSchemeManager.getIssueTypeScreenScheme(getFirstProject).name
to get the project's issue type screen scheme.
Now, I want to get the screen schemes that are part of this issue type screen scheme, and their association to each issue type.
Would this be possible?
Thank you!
Hi @arama mihai
For your requirement, you could try something like this:-
def schemeManager = ComponentAccessor.issueTypeScreenSchemeManager
def projectManager = ComponentAccessor.projectManager
def projectObjects = projectManager.projectObjects
def builder = new StringBuilder()
projectObjects.each{
it.issueTypes.each{ issuetype->
if(it.key == "MOCK") {
def issueTypeScreenScheme = schemeManager.getIssueTypeScreenScheme(it)
builder.append("\nProject Name: ${it.name}, \t Issue Type: ${issuetype.name},\t Issue Type Screen Scheme: ${issueTypeScreenScheme.name}\n")
log.warn builder.toString()
Below is a print screen of the code along with the output:-
Ram
Like • arama mihai likes this
Register now
