OK i will explain what i exactly i need.
atm. when solving "issues" for next release we mainly use 2 filters
current release filter - which main condition is fixVersion = earliestUnreleasedVersion()
future release filter - which main condition is fixVersion > earliestUnreleasedVersion()
these filters work well, and whenever we release version (Trough version management), boards update without issues.
now there is real question, since there are multiple people in team, and not everyone has work in "current release", i want them focus on "next release", while they see issues on "future release", they can pick from issues with lowest "fixVersion", but for better organization (and also easier planing for sprints) i really would like to make make board with filter for next release after earliestUnreleasedVersion()
earliestUnreleasedVersion() + 1 doesn't work (obviously)
with our release cycles we plan work ahead, and issues are spread(planned) 5 versions ahead (not counting special "FUTURE" version, which holds anything that is planned, but not in near terms, issues from there are moved to real version, when their time comes).
so let's say i have versions (for simplification i use year and month in sample - although are cycles are shorter)
2018-10 - released
2018-11 - current release worked on - not released yet
2018-12 - next planned release version
2019-01 - next planned release version
2019-02 - next planned release version
i can use fixVersion = earliestUnreleasedVersion() to see 2018-11
i can use fixVersion > earliestUnreleasedVersion() to see 2018-12 and other future versions
what i want to see is 2018-12, without need to change filter every time we release version (let's call it "next release filter")
when we release 2018-11 i want to have filter for 2018-12 (current release filter), but also for 2019-01 (next release filter)
have not found, how can i do that.
Hi Josef!
So, about your question, unfortunately, there isn't a nextUnreleasedVersion() function to help you with.
Digging a little further on the JAC I've just found this feature request:
- Allow filter by "Next Unreleased Version"
But it was marked as fixed, please take a look into this comment.
Seems like you can search using the following statement:
Also, take a look into this comment:
This function appears to use the order of the "Versions" in the list NOT the dates associated with them. Also, note the list earliestUnreleasedVersion() function expects the next list to be ordered with the old/next versions on the bottom of the list with future versions on the top. (I.E. From top to bottom: Release 6 -> 5 -> 4 -> 3 -> 2 -> 1 NOT Release 1 -> 2 -> 3 -> 4 -> 5 -> 6).
Hope this can help you out.
Best Regards.
Thanks for your reply.
Our versions are ordered correctly, so when i mark version as released correct version become “earlieastunreleased”.
now what i want is function that wil get me earliestunreleased() + 1, or if you prefer functional approach earliestunrealeased().next()
if there is no such functionality in jql, then i will stick with redoing filter for next unreleased manually, like i did until now, but it would be nice to have feature.
but i’m asking here, because someone might have needed this too, and solved it.
regards
@Josef Micka you might have more luck if you combine some of these statements.
fixversion not in (earliestUnreleasedVersion()) AND fixversion not in releasedVersions() AND project = PROJECTKEY
This at least gives you the remaining future fix version issues. You can then filter by Due Date or some other marker to see what needs work now.
@Lacey McDonnell, hi!
I have a problem, earliestUnreleasedVersion() always back No result value.
I have release dates and releases.
@Ludmila Romash FYI I get results for the filter (works for me):
@Tommo for some reasons, it works for not started release, I can't see current release with this filter.
But, thank you, I noticed that now it works
