How to get the field configurations using JIRA python api
Tejvir Singh June 12, 2018
I want the field configuration of a project. Like I want to know which field is required in a particular project while creating an issue and I want to get this information using Jira-python api. Is there a way to do it.
Tarun Sapra
From the docs
https://developer.atlassian.com/server/jira/platform/jira-rest-api-examples/#getting-metadata-for-creating-issues-examples
Discovering project and issue type data
To create an issue in JIRA, you first need to specify a project and issue type. These together are referred to in JIRA as an issue context and are used to find the JIRA schemes that control what fields are available for an issue, what the default values are and what fields are mandatory.
Using the createmeta resource we can discover the project and issue types.
Tarun Sapra
For rest call using python you can use this
https://jira.readthedocs.io/en/master/
Tejvir Saggu
June 21, 2018 edited
Thanks a lot. Solution provided by you works.
Tarun Sapra
That's great to hear @Tejvir Saggu , could you please accept the answer so that others are helped as well.
