How to get transition date in report(in JIRA OnDemand)
Kshitij Peter December 12, 2014
We have a workflow with states A to B to C to D and finally to E.  Now I want to report the dates that issue moved to state B or C or D or E.   I know there is a utilities function, which gives me a transition tab, but not sure how to use that.
I want to show in my report that transition date(say A to B or B to C) was this and present as a column in my report(or Issue navigator).
Roy Ha
October 11, 2016
As i know, IRA suite utilities is for JIRA Server.
How can i check transition date on JIRA Cloud?
Kshitij Peter January 3, 2015
One solution I came across is having custom fields and then setting them. Is there any other way like in Transitions tab provided by JIRA suite utilities, which just displays the data.
Paula Silveira
December 12, 2014
Hi Kshitij,
The plugin https://marketplace.atlassian.com/plugins/com.googlecode.jira-suite-utilities has a functionality named "Transitions Summary" that might help you.
Hope it works for you.
Thanks and regards,
Paula Silveira
Kshitij Peter December 15, 2014
Thanks Paula, But I am looking for someway to get that in my report.
