Hi all,
Is it possible to get the value of Tempo Worklog Attribute. We have 2 fields with the same name: 1 is scripted field and 1 field is work log attribute. We want to write a script to catch the value of Worklog Attribute and update it on Scripted Field because cannot export the value of Worklog Attribute to excel using Tempo.
The missing bit from CST's earlier example is that we now need a WorkAttributeValueService as well. Fortunately, the handy-dandy PluginModule annotation can fetch that for us.
This is an example of a Scripted Field that gets all worklogs of a particular attribute type (Overtime), and sums them. You can extrapolate how to get multiple worklog attributes and their values.
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.worklog.Worklog import com.onresolve.scriptrunner.runner.customisers.PluginModule import com.onresolve.scriptrunner.runner.customisers.WithPlugin import com.tempoplugin.core.workattribute.api.WorkAttributeService import com.tempoplugin.core.workattribute.api.WorkAttributeValueService @WithPlugin("is.origo.jira.tempo-plugin") @PluginModule WorkAttributeService workAttributeService @PluginModule WorkAttributeValueService workAttributeValueService def worklogManager = ComponentAccessor.getWorklogManager() def worklogs = worklogManager.getByIssue(issue) def overtimeLogs = worklogs.findAll { worklog -> def attribute = workAttributeService.getWorkAttributeByKey("_Overtime_").returnedValue workAttributeValueService.getWorkAttributeValueByWorklogAndWorkAttribute(worklog.id, attribute.id).returnedValue } overtimeLogs.sum { Worklog worklog -> worklog.timeSpent } as Long
Thank Jonny. I've tried it and I think it is not the solution in my case. Here is the part of code that I use to get attribute key "_JobType_" based on your script.
"_JobType_"
).returnedValue
Notice the last three lines of the script? That's the return value I used that sums up the timeSpent attribute of each worklog object. You'll need that or something like it to get the timespent as a number, instead of returning the WorklogImpl object itself.
I tried to adopt this to check whether there is time spent on an issue but it didn't work.
I replaced "_Overtime_
" with "timespent
" and checked timeLogs == 0.
What did I wrong?
If all that you want to know is whether any time has been spent on an issue, then you shouldn't need the Tempo classes at all. In fact, you may not even need the WorkLogManager. The getTimeSpent() method on the JIRA Issue object should suffice.
Hi Susanne and Mark,
Thank you for your quick answer. I've looked into it but It only allow you to get worklog info in JIRA for example: timespent, author, worklogid ... not worklog attribute on Tempo. Does Tempo have class available like this to get the value using Scripted Field.
ServiceOutcome<WorkAttribute> createWorkAttribute(WorkAttribute workAttribute);
ServiceOutcome<WorkAttribute> updateWorkAttribute(WorkAttribute workAttribute);
ServiceOutcome<Boolean> deleteWorkAttribute(
int
id);
ServiceOutcome<Collection<WorkAttribute>> getWorkAttributes();
ServiceOutcome<WorkAttribute> getWorkAttributeById(
int
id);
ServiceOutcome<WorkAttribute> getWorkAttributeByKey(String key);
ServiceOutcome<Collection<WorkAttribute>> getWorkAttributesByType(WorkAttributeType.Type type);
ServiceOutcome<Collection<WorkAttributeType>> getWorkAttributeTypes();
Don't use the rest API... you can use the java API. Our docs are mostly correct apart from the location of the WorklogAttributeService. I'll check it and get back to you.
Hi Jamie,
Where can I find the method summary of the following classes:
Thanks a lot,
Vladimir
Unfortunately, Tempo doesn't publish a JavaDoc, so there's not a good place to get their method summaries. The best you can do is point a tool like IntelliJ's decompiler at the tempo jar (you can unzip the downloadable .obr file that is on the marketplace) and see what you can divine that way.
Hello Jonny,
Thank you for the answer. I just want to to clarify some things:
In your script above I see that you used methods from class workAttributeService
(namely, getWorkAttributeByKey(
"_JobType_"
) and workAttributeValueService
(namely, getWorkAttributeValueByWorklogAndWorkAttribute(worklog.id, attribute.id)
). Where did you find those methods? Can I use something similar to get the TEMPO worklog object and then get the attribute's value of that log using Java API? Jamie in his comment above mentioned about java API.
Also, I wrote more about the problem I want to solve here https://answers.atlassian.com/questions/56472295
Thanks in advance,
Vladimir
Does anybody comment my question?
Thanks in advance,
Vladimir
We have a new section in our ScriptRunner documentation that covers how to work with Tempo worklogs.
I hope it helps.
Regards, Mark.
our docs are for tempo 7, it won't work with tempo 8. We're working on that.
Hi Jamie,
Here is the code I think can work with Tempo 8.0.0.2. But need to change something in the code. It doesn't work properly.
@PluginModule
workAttributeService.getWorkAttributeByKey("_OverTime_")
worklog.timeSpent
} as Long
// if no overtime worklogs just return null
Btw can above code get the worklog attribute value after modified ??
sorry - what do you mean by "after modified"?
Sorry. My point is can I modify your code on docs to get work attribute value. Let me try the code of Johnny Carter.
Since the release of Tempo Timesheets 8 it is possible to retrieve information about the worklog attributes via API (see http://tempo.io/doc/core/api/rest/latest/ for more information).
Please note that this API is private and subject to change.
Susanne
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
