We have recently enabled SAML and dual authentication for our Jira Server instance.
However, we are conscious that it is possible to bypass this authentication by just using the before valid password for the username.
Instead of just running a reset password for most users. I would prefer to see who is still accessing Jira via local authentication and not against our ADFS. Is there a database query one can use for this?
As I side note. We still have edge cases where SAML can not be users for all users.
As per my earlier response to Ed. I have seen that I can use the access logs to do what I want.
In the access logs, I can see that username/password logins are recorded in the following manner:
atlassian-jira-security.log:116053:2022-03-28 13:20:08,717+0200 http-nio-9001-exec-279 url: /login.jsp USERNAME... .../login.jsp The user 'USERNAME' has PASSED authentication.
All I did was to download the logs in a Support zip file and run the following PowerShell command against it:
$output = Select-String -Pattern "url: /login.jsp" -Path "atlassian-jira-security.log" | Select-String -Pattern " has PASSED authentication" | ForEach-Object { [regex]::match($_,"'(.*?)'").Groups[1].Value } | Sort-Object -Unique
So far, this is just an example of how I found the solution. There could be a more refined way of doing it. I am always open to further suggestions.
OK, so this relies on the /login.jsp being the "endpoint" where authentication has occurred. This will work, but indeed is not enough for what I was looking for – as I need to also catch rest updates and basic authentication for any endpoint
Hello, @ChristopherChilds
I am from TechTime, a vendor of EasySSO app, and just yesterday I had to resolve a matter (completely unrelated to SSO) where I needed to identify if the LoginEvent in Jira came from a REST request using basic authentication as opposed to the user actually logging in – I kinda discovered that it's not really possible to see at this level. Especially since that (as well as your question) relates to the default authentication pathway.
A 3rd party or Atlassian's SSO app can certainly record when the SSO login happens, but this is the opposite of what you are after.
I can only suggest to raise a query with Atlassian support.
Thanks Ed for the response. I think I have actually seen an alternative way to do this.
I am only really interested in seeing the users who are actually still logging in with the Login button and not via SSO.
This is actually recorded in the logs.
Looking at the Access logs, when a user logs in with the username and password and not via SSO I would see the following entry:
atlassian-jira-security.log:116053: 2022-03-28 13:20:08,717+0200 http-nio-9001-exec-279 url: /login.jsp USERNAME ... ... /login.jsp The user 'USERNAME' has PASSED authentication.
Via our SSO plugin the authentication is not logged here in this format.
your initial response and the two others were automatically marked as spam because of their content. I undid that and just wanted to let you know. Have a great day! :) Best, Max
