How to hide Epics from Kanban view?
Melvin
I switched from Scrum to Kanban view and already had some Epics. They're now displayed in the To-Do lane as moveable blocks and don't want Epics to be displayed on the board. The stories are already displaying in which Epic they are by the displayed label and I want to keep that.
How do I hide those Epics from being on my Kanban board?
9 votes
Adam R
What you're looking for is the type field in JQL
To filter out epics:
project = PROJECTNAME AND type != Epic ORDER BY Rank ASC
7 votes
Lilianne Riveron
August 21, 2020
You can enable the Epics panel in your board configuration. This will allow the epics to be displayed, but not as a card (ticket) on the board.
And in order for this option to show up, you need to enable the Kanban backlog, and this is done by moving a status to the backlog (in the example below, I added "Requirements needed" to the backlog, since I don't need to show those tickets in the board.
Deleted user September 11, 2020
This option, for some reason is not available for our instance of JIRA. Is this something that has to be enabled somewhere else?
Contramonk
September 12, 2020
Erick, I was unable to see the option as well. I took an item from the Backlog column and dragged it into the Kanban Backlog. When I did this the button for "Epics Panel" became enabled.
I found the directions here: https://support.atlassian.com/jira-software-cloud/docs/configure-columns/#Enabling-the-Kanban-backlog
ALEX DUTHIE
April 26, 2021
You can always create a quick filter which basically adds a button to the Kanban view:
  • Go to board settings
  • Go to quick filter
  • In the 'add' row do the following
    • Name the Filter Name
    • Add 'type != Epic' to the JQL field
    • Add a description
    • Add the filter
This should add a button the board like so:
david May 20, 2021
This is a good work around to hide Epic on Kanban but have them still viewable in the backlog. Thanks @ALEX DUTHIE
Niranjan
May 16, 2019
When i do this by changing the filter , i am not able to see the epics in the backlog too , is there a way to find them
Sarah Tipton June 21, 2019
me too! were you able to find a workaround for this @Niranjan ?
CN
February 6, 2020
No - I believe the backlog you are looking at is viewed through the same filter as your board. If you filter out epics in the board, you filter them out of the backlog too.
To the best of my knowledge you need to amend the filter, or create a separate board.
CN
February 6, 2020
But I note in our Jira Cloud account, in Board Settings >> Columns there is a toggle as follows:
Epics panel
Display epics in a panel in the backlog, and not as cards on the board
So a way to handle this is don't filter out epics from your board, and then do enable that toggle so your epics are in your sidebar rather than listed in your backlog.
Christian.Terrado
April 27, 2020
Is this toggle a feature on a specific version of Jira Cloud?
youcantgoogleme
May 19, 2020
But like this i still need the filter for the Kanban view right?
mavilchis July 6, 2018
The problem of using the Filter (!=Epic) is when you need to base the Swimlanes on Epics, .....
no information ......
kryzalid87
May 5, 2017
Had this same problem. Edit filter for board and add issuetype != Epic :)
Pablo Silva
You should be able to turn on Epic Panel switch on Board Settings / Columns, that will not only enable Epic Panel on side of Backlog but hide Epics at all on Board view.
Axel Jindra
July 3, 2020
Hmm... there is no such switch in my JIRA Cloud? Maybe part of a beta programme?
Like Nick Heath likes this
Johnny Hujol
February 22, 2017
Great! That's all I wanted to do.
Thx it's been bothering me for a while and this fixed it.
Here is the JQL filter I used
project = <my project> AND ((issuetype = Epic AND status != Done) OR (issuetype != Epic)) ORDER BY Rank ASC
Jobin Kuruvilla [Adaptavist]
July 10, 2016
You can modify the board's filter to exclude Epics. What appears on the board is determined by the filter.
Melvin
Could you be more specific where to find that filter or steps to apply that filter?
Nicolas Bourdages
July 11, 2016
When you go to Boards / Configure, under the General tab, you'll see the filter. Changing and editing the filter is all covered in the doc: https://confluence.atlassian.com/agile/jira-agile-user-s-guide/configuring-a-board/configuring-filters
