How to hide create subtask/convert to subtask in the more dropdown?
Colton Freeman September 27, 2021 edited
Is there a way to hide the options "create subtask/convert to subtask" in the more dropdown of the issue screen? I have seen options of this being done through workflow transitions but need some help doing so.
Martin Bayer [MoroSystems, s.r.o.]
HI @Colton Freeman , there is no way to remove these actions on Cloud. The only chance is to remove sub task issue typesfrom your issuetype scheme. You can find more information in already existing thread:
https://community.atlassian.com/t5/Jira-questions/How-to-hide-create-subtask/qaq-p/1749788
Roberto Miasack
September 27, 2021
Hi @Colton Freeman
Could you talk a little more about your question? Does removing subtasks from the project solve your question?
Cheers
Learn more
