How to hide the field name for a message custom field (for edit)
Prathap DL
I'm setting up a new project. In it, there are several fields that must be divided into different sections. I've been thinking to separate these sections with a message custom field (for edit). The problem is that the field name appears too, so this solution is not aesthetically pleasing. Below an example:
What I want is to hide the words "Connection 1 (input data)", which represent the field name, and leave only the box below containing "CONNECTION 1".
Please let me know your thoughts and suggestions on this topic.
Tomislav Tobijas
Hi @Prathap DL ,
Why couldn't you create just one generic field that would contain all those 'sections'? In your example, the field named Connections and then just paragraph-styled content inside for each connection? 👀
I don't think anyone else requested something like this (you can potentially check here) you could also discuss this with the support team and maybe they could create new suggestion based on your requirement.
Tobi
