How to import from CSV into Jira Product Discovery project
Jennifer Choban - HeroCoders
I want to import from a CSV into a JPD project. The documentation says:
Import the CSV file into Jira Product Discovery
  1. Click the + Create button located at the top navigation bar > next to Configure form, click (arrow icon).
  2. Choose the CSV file you want to use and click Next.
I do not see either "Configure form" or an arrow icon.
Thanks in advance for any suggestions.
Mikael Sandberg
You are looking at the wrong +Create. The +Create button mentioned in the documentation refers to the +Create button all the way at the top, to the right of the search bar. From here you will see the Import work items.
Thanks @Mikael Sandberg
Like Mikael Sandberg likes this
