I have a .csv file, formatted in hierarchy order from top to bottom including a column for issue ID and a column for Parent which includes that issue ID. I want to import in a SINGLE import step. I am able to do this with issue linking but cannot do it with parents. Why not?
I am using:
@MechEngStud1122 Welcome to the Atlassian community
The issues needs to be a sub-task to have a parent. If it is a sub-task and the parent issue has already been created then you just use the issue key. If you are creating the issue at the same time of the sub-task you will need an issue id in your CSV. See example table below.
IssueID | ParentID | IssueType | Summary | Description |
1 | Task | one | This is one | |
2 | 1 | Sub-Task | two | This is two |
3 | 1 | Sub-Task | three | This is three |
4 | Task | four | This is four | |
5 | issue-123 | Sub-Task | five | This is five |
Learn more
