×Hi,
How to import new sub-task in CSV to existing parents in jira? I want to match tasks(parents) that already exists in jira with sub-task (childs) which are new. What fields do I need to fill in in csv to make such a connection?
Hi Sabina - Welcome to the Atlassian Community!
Just add a column to your CSV for Parent. Then put the issue key of the existing Parent into that column for the sub-task. For example, ABC-123
Summary Parent
Sub-task 1 ABC-123
Sub-task 2 ABC-123
Sub-task 3 ABC-123
You are welcome
