How to import zephyr test cases with execustion result and test cycle into jira
Sachin Dhamale
Hi Team,
I want to import test cycle and test cases with execution result into jira.
1. Is there any importer to import test cycle in the jira
2. Is there any importer provided by zephyr to import test cases with test steps,expected result , actual result and test execution result.
Sachin
David.Werner May 24, 2020
Still waiting for a Zephyr Execution Import tool
Karen Mixon May 31, 2019
Zephyr support--still no execution import?
Peter Zhou September 6, 2018
Just wonder if we still NOT having any importer to handle test execution?
Peter
Arun Mani
July 24, 2018 edited
N
Arun Ravindran
Hi Sachin
Thanks for your interest in Zephyr
1. Is there any importer to import test cycle in the jira--> There is no importer to import test cycles in Jira
2. Is there any importer provided by zephyr to import test cases with test steps,expected result , actual result and test execution result.-->Yes we do have an importer utility where in you can import test cases,test steps and expected reult but you cant import any data with regards to execution.
Please go through the user guide for the importer utility and the sample excel sheets attached at the end of the article in the link below
https://support.getzephyr.com/hc/en-us/articles/204550179-How-do-I-import-test-cases-into-Zephyr-for-JIRA-Cloud-
ZephyrSupport
Disha Suryawanshi
August 24, 2017
How we can see the test case  which are imported  what are the steps to see the test cases in jira after successful import
Deleted user December 8, 2016
Are you using Zephyr Enterprise or Zephyr for Jira?  ZE allows to export the details you mentioned in your question, but importing the details into JIRA is not easy. What is the purpose of making a project management system into a test case management system? Rather, you can link the stories as requirements in Zephyr and create your reports.
