Zephyr Scale is used.
I have multiple Test Cycles that I want to assign to the same person.
How to assign them in one action, without having to this for every test cycle seperatly.
Hi Ellen,
I sent a reply and two workarounds on the Smartbear forum. The API is probably the most effective solution if you have a lot of cycles to update, but if you're working with a smaller number, I have proposed an alternative UI workaround.
Cheers, Andy
Hi Andy, Thanks a lot for the feedback! This is very helpfull information.
Welcome to community :)
You can check the doc on the app side : https://support.smartbear.com/zephyr-enterprise/docs/en/zephyr-enterprise/zephyr-user-guide/test-planning/assigning-test-cases-to-users.html?sbsearch=Bulk%20assignement%20cloud#bulk-assigning-test-cases-to-users
Or reach out to https://support.smartbear.com/ to further check this
Thank You,
Prachi
Thanks for your reply. I have raised a question on the smartbear community, since we are not using the enterprise version.
