I've automated a Slack message every morning for urgent tasks due within a week.
I would like to know how to include the name/summary of the parent issue in this message (doesn't need a link), as it can be confusing to have only the sub-task summary without its parent.
Here is the message:
Good morning <@xxxxxxxxxx>!
Here are your most urgent tasks over the next week, sorted by due date and priority
{{#lookupIssues}}
• <{{url}}| {{issue.parent.key}}> <{{url}}| {{issueType.name}}: {{summary}}> | Priority: *{{priority.name}}* | Due in: *{{duedate.diff(now).days.abs}} days*
_Please put a Due date if "Due in" field is blank._
If you need help with any task, check the "Other members assigned" field on the task to see who to ask.
I would appreciate any help with this! Thank you
When you are inside of the lookup issues iterator, just refer to the field name's smart value and not {{issue...}} Then you would just need {{parent.summary}} inside the lookup loop.
Hi @Niccolo Ossude ,
I'm Nithaya from the Automation team here at Atlassian.
Did you manage to make it work with {{issue.parent}} ? It should work with {{#lookupIssues}}.
If not, can you share any more detail or a screenshot about the automation rule you were wanting to create, to help us understand how we can support your use case?
Nithaya.
Hey @Niccolo Ossude
Welcome to Atlassian Community !!
Is the parent issue the Epic Issue type ?
Did you try {{issue.parent.epic.summary}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--issue.parent--
The above URL lists the available smart values for {{issue.parent}}
Hope this helps !!
Vishwas
Welcome to the Community!!
May I know if it's not working or are you looking at suggestions?
Let me know
Pramodh
Thanks @Pramodh M and @Vishwas !
I've tried to use smart values for {{issue.parent}} from
but these aren't working, I believe these don't work when I use {{#lookupIssues}} ? This is the only explanation I have right now.
Also, the Slack message includes Tasks and sub-tasks, but my priority is to include the Task name for sub-tasks. Having the Epic name for the Tasks would be a bonus.
