My objective is to setup sequential stories within different Epics. I am looping through the epics and would like to have a staggered start date so that each epic starts at a different date.
I have created a startDate variable before the branching.
Within the branch, I'm trying to increment it so that in the next loop, the date to be used is the incremented one.
I understand the branches in fact run in parallel so this solution does not work.
What is the recommended way to achieve what I want ?
Stylized version of my automation below
Hello @TP
It is not currently possible to increment a variable in a branch. That change request is included in this change request, to which you can add your vote:
https://jira.atlassian.com/browse/AUTO-26
Hi @TP
As Trudy described, that variable cannot be re-declared to update it, or to update it sequentially.
For this type of scenario, there is a workaround for the parallel processing of branches using variables, and it requires some assumptions:
Now, the how-to part:
List elements have an index, or counter for each item. They are numbered 0 for the first item, 1 for the second, and so forth. Please look here for documentation on index: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/#Combined-function-examples
And so {{index}} would be a great thing to use for your list of epic names as a way to multiply a number of days to increment the date. The problem is {{index}} appears to be unavailable for anything other than displaying the number: it cannot be used in a function, such as {{someDate.plusDays(index)}}
But what if we could capture the index for use later to increment the date variable? We can!
First convert your manual trigger, input variable of epic names into a list stored in a variable, using the split() function and {{.}} for item value:
{{#userInputs.epicNamesString.split(",")}}{{.}},{{index}}{{^last}};{{/}}{{/}}
This will produce a variable value like this, where we have name / index pairs:
make plan,0;buy materials,1;build shelf,2;store books,3
For the branch over the values, we split that back apart into pairs:
{{varEpicNameAndIndex.split(";")}}
Inside of the branch, we may how access and use the two parts like this:
epic name: {{varOneEpicAndIndex.split(",").get(0)}}
new date: {{varStartDate.toDate.plusDays(varOneEpicAndIndex.split(",").get(1).asNumber)}}
Please adjust the date increment and delimiters, as needed.
Interestingly, I have seen several questions in the last few weeks that can be solved using this same technique of build-your-own-list, sometimes including dynamic searching. Perhaps its time to write an article to generalize this a bit for reuse.
I'd suggest this type of workaround is more than a little bit hacky, although likely to continue working after future automation improvements ;^)
There is an open suggestion to add an option for parallel versus sequential execution of rules (such as for branches). You may vote for / watch it to see any progress: https://jira.atlassian.com/browse/AUTO-32
Given the potential for service limit violations when a hypothetical, sequential rule runs too long I hypothesize this suggestion may not be implemented without another limit change by Atlassian.
