How to integrate HP ALM with JIRA, need steps to integrate
Senthilvedhan September 12, 2016
This question is in reference to Atlassian Documentation: Integrating with other tools
Whats the steps/procedure to integrate HP ALM to JIRA.
Community moderators have prevented the ability to post new answers.
Post a new question
3 votes
francis
Hi Senthilvedhan,
Exalate is an issue synchronisation solution providing bidirectional synchronisation between multiple issue tracker types including JIRA, JIRA Cloud, HPALM.
Send us a mail to info at exalate dot com for more information.
Francis
Sai kiran P
Hi All,
Is HPSYNC2 supports with JIRA 7.13.13?
Thanks in advance
Brad Peterson
Hi Saikiran and Senthilvedhan,
You can try our Opshub Integration Manager – Free Edition that can be downloaded from OpsHub Community Portal. The free edition supports bi-directional integration for Jira, ServiceNow, Azure DevOps Server (TFS), Micro Focus ALM (HP ALM), and Azure DevOps Services (VSTS). All key features of OIM paid edition have been included in the free version. The users of OIM free edition will also get complimentary lifetime customer support through the OpsHub community.
A detailed list of OIM free edition features is available here.
You can also reach out directly to us.
Sandeep Jain April 6, 2017
Senthilvedhan, you can integrate HP ALM with JIRA using 3 steps process. 1st you connect the two systems,
2nd you do workitem/entity mappings with fields and values,
3rd you can integrate the systems selecting project & other parameters
To know more how you can achieve this do check this out of the box integration solution https://marketplace.atlassian.com/plugins/com.opshub.product.oim/cloud/overview
You can also reachout directly to us.
SamVijay May 24, 2019
How the two systems will be connected . By what means??
Like • Brad Peterson likes this
RG
We can integrate both Applications via ConnectALL tool.
1. We have to create connection link
2. We have to configure URLs, Domain and Project
3. Field Mapping with values
Then enable the connection link.
Jobin Kuruvilla [Adaptavist]
September 13, 2016
Take a look at ConnectAll as well. You can request for demos.
Nic Brough -Adaptavist-
September 12, 2016
"integrate" is a "suitcase word" - it gives us a rough idea of a concept, but tells us nothing about what you really want because it could be a container for all sorts of things.
So, to "integrate"
  1. Define what you want to get from your "integration"
  2. Have a look in the marketplace to see if there may be anything you can use to help you with it (For example, what Francis said in his comment, which should really be an answer so we can vote it up wink )
  3. If not, then you'll need to look at the REST APIs for JIRA and whatever integration points HP ALM may have
Post a new question
Learn more
