Hi! I'm trying make this:
Create issue if column D in https://docs.google.com/ was edited
So it is done, but I have no idea how to create issue and copy information in task from column C (from same row)
Example: IF column D and which row 12 (or 13 or 14, it doesn't matter) was edited, THEN issue created and description contains information from column C and row 12 (or 13 or 14, it doesn't matter)
issue created because works this script in GD:
function editRow(e){
if(e.changeType=="EDIT" || e.changeType=="INSERT_ROW"){ //The type of change (EDIT, INSERT_ROW, INSERT_COLUMN, REMOVE_ROW, REMOVE_COLUMN, INSERT_GRID, REMOVE_GRID, FORMAT, or OTHER)
var spreadsheet = SpreadsheetApp.getActiveSpreadsheet(); //get activated Spreadsheet
var sheet = spreadsheet.getSheetByName("Sheet1"); //get sheet by sheet name
var headings = sheet.getDataRange().offset(0, 0, 1).getValues()[0]; //get heading
var column_to_watch = 5; //A=1, B=2, C=3 etc...
var row = sheet.getActiveRange().getRow();
var column = sheet.getActiveRange().getColumn();
if (e.changeType=="EDIT" && column != column_to_watch)
return;
var values = sheet.getSheetValues(
row, // starting row
1, // starting column
1, // number of rows
4 // number of columns
var payload ={}
for (i = 0; i < headings.length; i++) {
var name = headings[i];
var value = values[0][i];
payload[name] = value;
payload["row_number"] = row;
var options = {
'method': 'post',
'contentType': 'application/json',
'payload': JSON.stringify(payload)
and automation for jira
What I sholud add to realize this feature?
