×I'm currently using the method user/permission/search to know if user has a given permission for a given project. The problem I have is I'm not sure if the method is using the security schema and the issue selected level.
Is it possible that the user is returned although the user is not included in the issue security level?
Hi Robert, please ignore this question. I was using the project key instead of the issue key when searching for permission. Yes, I'm creating an AC addon
Are you writing an Atlassian Connect add-on?
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
