How to limit sprints in sprint field to dedicated project
G Ashok
Hi Team
I especially appreciate the new spint field, which allows you to add an issue to a sprint as it is created.
However, as you begin typing to discover your sprint, sprints from other projects appear, and because they frequently have the same name in multiple projects, it is impossible to identify which is correct.
I don't think it makes sense to show sprints from other projects, therefore perhaps this can be resolved?
I searched but found nothing, so I figured I'd start a thread about it.
Bryce Lord
August 9, 2024
Hi @G Ashok ,
When selecting the sprint from the sprint field, there should be a checkbox to "Only show sprints in this project". Selecting this will limit the sprints shown in the selection to only those within the project the issue is being created.
For more information see the link here: How to limit the Sprint field to only show active or future sprints in the current project
Hope this helps!
G Ashok
Hi Bryce Lord
When you select the checkbox, sprints from other projects still show up. We were running into an issue where BAs from other projects were able to delete our sprints, add their stories to our sprints, etc.
