We have a few vendors that we want to collaborate with using projects in our Jira instance.
Requirements:
Each vendor can only see the project and issues within the project we are collaborating with them in.
No Vendor can see all of the projects within our Jira instance.
What I have tried that has not worked.
Steps to create vendor restricted access | |
1 | Created a specific vendor Role |
2 | Created a specific vendor group |
3 | Created a Vendor Restricted Permission Scheme Notes: I created a copy of our standard permission scheme then edited groups and roles. Examples Browse projects I removed "Any logged in user" and added Project Admins and Team Members Added the specific Vendor role to: Assignable user, Create issues, Transition issues, Add comments, etc. |
4 | Created a vendor specific project |
4a | Used the Vendor Restricted Permission Scheme |
4b | Added the specific vendor group, assigned to the vendor role |
I invited 3 testers outside of my org to the specific vendor group, when they logged in with their NEW Jira credentials, they can see everything, all projects all issues.
What step did I miss?
Do I need to change all of our standard permission schemes to replace "Any logged in user" with specific groups?
Help will be greatly appreciated.
Pat
Hello @PATRICIA MURPHY
You said you want the Vendors to see only a subset of your projects.
You said you created a new Permission scheme where you removed the Any Logged In User permission allocations, and added the Vendor specific role.
To which projects did you apply that permission scheme?
If you applied that only to the projects you want your vendors to see, and all the other projects still use a permission schemed that grants access to "Any Logged In User", then that permission scheme on those other projects is configured to allow the vendor users to see them.
To prevent your vendors from seeing projects you need to ensure that the projects they should not see use permission scheme(s) that don't grant permissions to
Public
Application Access
Any Logged In User
The vendors will be able to see any project where the Browse Projects permission is granted to the above.
You also need to make sure that the vendors are not added to any group or role that is granted the Browse Projects permission in those projects' permission schemes.
To give them access to the projects you do want them to see your use of a vendor group and vendor role is correct. That applies to the projects you do want them to see.
All of the above applies to the Company Managed projects in your instance.
Another thing to consider is whether or not there are any Team Managed projects in your instance.
Team Managed projects have an overarching Access setting in each project. The options are Open, Limited, and Private.
The Open and Limited options make the projects visible to anybody with access to your Jira product. To prevent the projects from being visible to the vendors the Access setting in each one would need to be changed to Private. With that setting only the users assigned to roles in the Team Managed project can see the project.
@Trudy Claspill Thank you very much for your reply.
I am working in our sandbox.
I modified ALL permission schemes currently in use by projects to remove the
Application Access, Any Logged In User and in place of those ,added roles that should have the permission like Project Admins and Team Members.
For the Vendor permission scheme I made sure there were no permissions in it designating Application Access or Any Logged In User.
We did not have any permissions in any schemes with public.
I then logged in as one of my test users that is part of a vendor group, that is in a project using the Vendor permission scheme, where the specific vendor group has the vendor role.
I was still able to see all of the projects and issues, I will have a fresh tester check tomorrow and see if they have the same results.
In case it makes a difference, there are a few unused permission schemes that I did not bother to clean up.
Thank you
Pat
Can you share with us the details of the Permission Scheme associated with one of the projects the vendors can see but should not be able to see?
Update - So last night when I logged in as one of my test users who is part of a vendor group and I still saw all of the projects and issues was a fluke, maybe because I was logged in with my real account in another browser tab.
The good news is that my fresh testers logged in this morning and can only see Team managed projects and JPD projects which now need to be changed to private.
Thank you!
Thank you again @Trudy Claspill
The key was to remove Application Access, All logged in users from all of the permission schemes being used in our Jira instance!
If you're interested in Marketplace add-ons, take a look at Issue Sync Pro (developed by the company I work for).
This tool can help by enabling controlled issue sharing between your Jira instance and external vendors without giving them full access to your internal projects. Specifically, you can:
This is a link to IS Pro Support Center if you want to read more :)
@PATRICIA MURPHY if i understand, you have 3 jira projects and you want each vendor has access to only one project and issue within it?
If that is correct you can have same (standard permission scheme) for all projects and give all the permissions you want to the vendor role you already created.
Then for project 1 in project settings / people, you can add vendor 1 with the Vendor role...
Project 2 - vendor 2 etc ..
In the Permission scheme you can define that Vendor Role what the vendor can do...
In the Project 1 project settings /people you can assign particular Vendor or group of Vendor users to the Vendor Role... In that case assigned Vendor(s) 1 will have access only to project 1...
In the permission scheme what the vendor role can do...In People you define who is the vendor for that project.
Make sure that each Project has Private access and only people added by admin have access to it.
Thanks for the quick reply, I think I tried what you are suggesting in Step 4.
I created a project for a specific vendor, under people I added the specific vendor group with the vendor role.
I am stumped.
1. Are your projects private?
2. Do you use same permission scheme for all projects?
3. Does your permission scheme have only Project roles assigned to certain permissions or User groups too(vendor user group or jira-users or any default jira user group)?
If your permission scheme contains jira user groups:
1.since all created accounts are added automatically to the default jira groups (e g. Jira-users), remove all user groups from permission scheme ( except administrator groups)
2. In your permission scheme, Grant wanted permissions to the Project Roles you have...
3. Assign users or user groups to Project role in each project (project settings/people)
