How to link a custom field to another custom field
Liam Maeder
I want to create a check box custom field that when checked opens up another custom field related to it e.g:
If i check RFA attached then a multi line input field should open up.
Thanks for any help
Joe Pitt
You can't do it out of the box. Being in the cloud you have limited options for plugins. If you have scripting you may be able to do it.
Liam Maeder
Unfortunately I dont.... Maybe you could recomend a few plug ins?
thanks
Register now
