Hi there!
My script queries a REST Api and retrieves some JSON data (version information of software releases). This works so far.
Now I need to use this data to refresh the possible options of a custom field (of type select list or even better a cascading select list). Users should be able to create a new bug report and chose the affected version.
But I simply can't get this part to work.
I think I have to use the OptionsManager (Atlassian Jira - Server 8.20.13 API), but I couldn't find a working example.
Can anyone help me!?
Solved using several existing community posts, e.g.
Solved: ScriptRunner - Can I update Custom Field options a... (atlassian.com)
How to delete option value from custom field (atlassian.com)
