How to make Epic as a defualt issue type for create screen
Narendra Kumar
Hi Team,
For one of my project I want to make Epic as a default issue type all the time when I'm going to create the issue.
Generally, Jira save the previous issue type and it will be showing to us when we'll create issue next time.
Can configure in a way that all the time Epic should appear in issue ttype dropdown and no need to check about issue type selection?
Let me know if it;s feasible to do. Thank you in advance.
Narendra
Chris Buzon
September 17, 2021
Yes, go to the Issue Type area in your settings, then select Epic as the default.
This is a per-project setting, so you'll have to be sure you're set to the correct project, or do this in every project.
This affects everyone using the project.
