I do not see the option to set the Assignee to Required in the field configuration.
So, any idea how to make it mandatory in one Jira project and optional in other Jira project ?
Workflow validation can be option but that's not good enough;
I want all the mandatory fields behave the same, with red *
Gal
Hi @Gal Fatal ,
Presently this is not possible. https://jira.atlassian.com/browse/JRACLOUD-1001
2 workarounds:
1. set Allow unassigned issues to OFF
https://confluence.atlassian.com/jirakb/making-assignee-field-required-when-allow-unassigned-issues-is-turned-on-in-general-configuration-604209943.html
2. Use validator or plugins.
Hi @Gal Fatal
This can't be done.
You have the workflow option or the option in the general settings to disallow unassigned issues on global level.
Or use a 3rd party app JSU, see making-assignee-field-required-when-allow-unassigned-issues-is-turned-on-in-general-configuration
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
