How to make custom fields show up by default on screens instead of needing to use the configure fields dropdown?
Isaac Myman January 19, 2015
I have 2 custom fields which I have added to the create bug report screen. They do not show up by default. I have them set to required and show in the field configuration. I can make them show up, but only if I go to the configure fields dropdown and select them.
Andre Borzzatto
January 20, 2015
Hi Isaac,
There's not much information on what's it that you want to setup, but I think that it might relate to the View Issue screen operation.
Any field with a value that you make available in the View Issue screen operation will start to show up by default.
More information on setting up screens and field can be found in the following documentation:
If you need any further assistance, please share some screenshots and drawings with us to explain in details your desired setup.
Read the story
