How to make "New Feature" issue type highest level in hierarchy above epic using structure plugin
prasad Biddika December 27, 2022
How to make "New Feature" issue type highest level in hierarchy above epic using structure plugin?
Please guide using structure plugin. we are not using Advanced road maps
Thanks!!
Yulia Barbash _ALM Works_
Hello @prasad Biddika
Welcome to the Community.
You would need to add an issue link that links New Feature to Epic.
Then to build your structure use the Insert generator with the JQL: issuetype = “New Feature”, and add Extend generator to extend linked issues and choose the link type you are using and for better performance specify the level you are extending.
Let me know if it works for you.
Best regards
Yulia
