How to make the resolution field editable?
Andrea S February 15, 2022
3 votes
Mikael Sandberg
Hi @Andrea S,
The resolution field is a special one, and you can only edit it if you add it to a screen, change it as part of a post function, or set it using an automation. So, do you want to change because it it wrong or do you want change it when moving your issue to the done status?
Thanks for the warm welcome and fast response!
Not sure what the answer is : add it to a screen or change it as part of a post function.
I want a dropdown box, with the following options, to select 'why' the ticket is 'done'.
Mikael Sandberg
Okay, so you would have to create a screen that has the field resolution on it like this:
Then in the workflow on the transition that moves the issue to Done, Edit the transition and add the screen you just created. Then on the post function, make sure that you do not have one that sets the resolution field.
Like • 4 people like this
How can I add a screen on the workflow? Am I editing the wrong workflow?
Mikael Sandberg
Oh, you are using a team-managed project. Unfortunately your cannot use a screen to set the resolution in those project. And the only resolution that will be set is Done, and it is done when you move the issue to the far-right column. Currently it is only company-managed projects that allows you to select the resolution.
Like • Ben Z likes this
Got it. Thanks a lot Mikael!
Like • Mikael Sandberg likes this
