How to mark an issue as a Regression Bug or Reopened Issue
Uri
June 4, 2024
I want to be able to mark some issues as a Regression and Reopened. Looking at custom fields, I couldn't find any boolean fields to add. Any idea how to do that?
  • Regression: should be true/false or true/none field (boolean).
  • Reopened: should be a true/false or true/none field (boolean), that can't be set or changed by a user - it changes be a rule (when transitioning from Resolved to Todo)
By now, it works if I use text fields, but since it's not a boolean, the searches become complicated.
How can I use a boolean field as a custom field? Is there any other option for that?
Stevan Mandić
June 5, 2024
@Uri you can create select list (single option) custom fields and define options in custom field configuration (context & default value)
Option 1: True
Option 2: False
Nathan Phillips
June 5, 2024 edited
Hello @Uri
I agree with @Stevan Mandić, a Select List custom field would be a great option to meet your needs.
More information on how to configure custom fields can be found here
Like • Uri likes this
Uri
June 5, 2024
Thank you @Stevan Mandić and @Nathan Phillips .
I was looking something like a boolean. The problem with strings is when doing a search, because not all the 'not true' are marked as 'false', because most of them can have this field empty
Stevan Mandić
June 6, 2024 edited
@Uri
You can solve that problem in 3 ways
1. If you have true and false options set, you can treat "empty" as False
So your JQL for false state will be (field=False or field is empty)
2. Set default value for the field (for instance: False) and you will not have issues with empty field.
3. Instead of using two options, use only one option - True.
Then you will have 2 states of the field: True & empty ( non-empty & empty)
Like • 2 people like this
Upcoming Jira Events
