How to migrate Risk Management Projects
Asha March 18, 2024
We are trying to migrate risk managed project from server to DC.
Data's related to risk plugin was not migrated and couldn't find a way to migrate these.
Can someone help on this?
Asha
Monika Isak
Hi @Asha ,
You will simply need to activate the license of the SoftComply Risk Manger Plus application for Data Center.
For Server and Data Center the app functionalities are the same and the data will be migrated seamlessly.
I hope it helps!
Monika
Asha April 2, 2024
Hello @Monika Isak
We do have a valid license. We usually use CMJ plugin for migrations. But few things not coming while using this method for RMP projects.
Monika Isak
Hi again Asha,
I believe that this is the same use case that SoftComply is currently actively supporting via our Support Portal.
Worth mentioning here as well, that this case involved a new DC instance (with a separate database), not a straightforward Server to DC migration.
Looking forward to getting the last remaining open items sorted for you and your team.
Hana Kučerová
Hi @Asha ,
which application exactly are you using for the risk management?
Thank you!
Asha April 2, 2024
Hi @Hana Kučerová
We are migrating project from Jira software and  using Risk Manager Plus by SoftComply plugin in both the applications.
Help us plant more trees
