How to move tasks with custom statuses to next sprint?
Amulya Sankara
I have created custom statuses for my Software Team, like Code Review, Acceptance, Test Env, etc. All these custom statuses are assigned to 'Done' status as per our internal workflow.
Now when we complete one sprint, we want to also move issues with the custom statuses to the next sprint. This is because although they are assigned to 'Done', we need the issues to reach the final status of 'Done'.
However, Jira only allows the open issues to be moved to the next sprint. Since the custom statuses are assigned to 'Done', Jira considers them part of the Done column in the board. For analysis and reporting purposes, we would like to have the custom statuses to remain in the 'Done' column.
So is there a way to create a setting where I can move all issues to the next sprint, i.e all issues without the final 'Done' status?
3 accepted
Vishal Biyani
February 19, 2025
@Amulya Sankara
You can try below automation:
Trigger
Sprint Completed (Specify the board)
Branch
For each issue in the sprint
Add If
check issue field condition (status in ("Code Review", "Acceptance", "Test Env"))
Edit Issue
Select Field as Sprint and in the box select Next Sprint
Amulya Sankara
Great, this looks like a good option. Thanks, I will try this!
Vishal Biyani
February 19, 2025 edited
@Amulya Sankara
in your sprint board view, what is the statuses mapped to right most column?
if you remove your custom statues from right most column, I believe, you should be able to achieve your use case when closing the sprint. Issues with these statuses will be moved to next sprint.
Check and let me know if this works for you
Amulya Sankara
Yes I thought of this. However, we would like to keep the custom statuses in the right most column since they all essentially are assigned to Done and this will mess our sprint analysis.
Thanks for the suggestion!
Nikola Perisic
Hi @Amulya Sankara
One of the ways you can actually do this is bulk transition and moving issues to the next sprint:
  • Issues > JQL
Query: status in ("Code Review", "Acceptance", "Test Env") AND Sprint in openSprints()
Then you select three dots and select Bulk Change.
You would then select Transition issues to move them to the next sprint and assign correct values.
Amulya Sankara
This sounds like a good solution. Do you know if I can add any Jira Automation for this, so that I can do this at the end of each sprint?
Nathan Phillips
February 19, 2025
Hello @Amulya Sankara,
Below is a direct link to our smart values for automation, specifically smart values for Sprints:
https://confluence.atlassian.com/automation/jira-smart-values-issues-993924860.html#:~:text=rule%20actor%20user.-,sprint,-Added%20by%3A%20Sprint
Like • 2 people like this
